Ezechias
Sep 09, 2015Aspirant
Where to download TEAMING Add-on ?
Hello,
I found many thread about the LACP link aggregation but all links related to download the team add-on, has a 404 error or is down. Can someone plz send me the link. I have a ReadyNAS Ultra 2 Plus.
Thanks.
Thank you all for your responses. I have been exchanging private messages with a Netgear support agent and he remote accessed the NAS, under support mode, to activate the business features. I now have the teaming option appearing under interfaces, without any add-on.
- EzechiasAspirant
I don't think you'll see much improvement in speed. In fact, LACP teaming won't give you any speed increase at all unless you have multiple simultaneous users.
But I think the post you are looking for is here: (super_poussin post; 2009-10-16)
Good New guy, my teaming add-on always work after an upgrade :)
you can try it :http://www.readynas.com/contributed/sup ... am_2.1.bin
please reboot after changing Teaming mode and values
Please also notice , the ip @ of your nas can change after teaming.- RootaxLuminary
And BTW, I know that OS6 is not supported by netgear on Ultra 2, but you don't need a plugin with the new OS, if you decide to give it a try ..
Correct. OS6 is another option if you are willing to rebuild the NAS/restore the data from backup. It is unsupported, but if you are out-of-warranty anyway that might not matter that much to you.
Personally I wouldn't do that just to get teaming - as I said the gain is marginal for most home users.
