PhotoJoseph
Jul 26, 2021Tutor
Will adding second network interface with second ISP speed up WAN data transfer?
I have a ReadyNAS 2312, used primairly as a local backup destination for large video files. I have it set to sync to Dropbox (I have an unlimited business dropbox account) for an offsite backup. It's...
PhotoJoseph
Jul 26, 2021Tutor
Thanks StephenB — so it's down to the app, hmmm.
Jul 26, 2021Guru - Experienced User
Yes. If the app is making one connection to the dropbox cloud, then that connection will go over one interface. If the app doesn't select the interface explicitly, then Linux will select it - most likely picking the first one.
If the app is making multiple connections, then it might be smart enough to use both interfaces (or not).
My guess is that the app isn't that sophisticated, as most folks don't have two ISPs.
- PhotoJosephJul 26, 2021Tutor
Makes sense. OK, thank you very much.
