Dashu
Jan 10, 2012Aspirant
Wordpress requires newer php
Followed the tutorial here: http://www.readynas.com/?p=213 Only to end up with the following error: Your server is running PHP version 5.2.0-8+etch16 but WordPress 3.3.1 requires at least 5.2.4. ...
mdgm-ntgr
Jan 10, 2012NETGEAR Employee Retired
You'll need to remove that PHP and install a community add-on that meets or exceeds the WordPress requirements
Have you loaded data on the unit yet?
If not, or if you haven't loaded much it might be simplest to backup your data, do a factory default and start over.
