Dashu
Jan 10, 2012Aspirant
Wordpress requires newer php
Followed the tutorial here: http://www.readynas.com/?p=213 Only to end up with the following error: Your server is running PHP version 5.2.0-8+etch16 but WordPress 3.3.1 requires at least 5.2.4. ...
mdgm-ntgr
Jan 11, 2012NETGEAR Employee Retired
You need to be quite careful to uninstall it and remove any files for it that might get left behind. If it's not done right you might lose Frontview access (though this can be fixed via SSH). However if you used e.g. WhoCares?'s add-on if you have problems you could ask him for assistance and he might be able to suggest a few places you may have missed or even possibly provide remote assistance (e.g. using TeamViewer - a remote assistance app where you share the screen so you can see what he's doing to fix a problem).
