Dashu
Jan 10, 2012Aspirant
Wordpress requires newer php
Followed the tutorial here: http://www.readynas.com/?p=213 Only to end up with the following error: Your server is running PHP version 5.2.0-8+etch16 but WordPress 3.3.1 requires at least 5.2.4. ...
WhoCares_
Jan 11, 2012Mentor
Different problem. When PHP reports the mysql(i) extension to be missing, it's most likely a problem with the PHP add-on install. If, however, it reports to be unable to connect to the MySQL database, then one of the possible causes is that MySQL isn't running. That of course can be fixed using MySQLOn.
-Stefan
-Stefan
