savek
Dec 29, 2016Star
Zoneminder and VLC libs - ReadyNas 204 ARM
I just have a fast question to ask. I am trying to install the VLC and the libs to test the libvlc in Zoneminder app. When I try to to issue command : apt-get install libvlc-dev libvlccore-...
JennC
Jan 04, 2017NETGEAR Employee Retired
Hi savek,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
