Trial_Master
Sep 23, 2017Aspirant
1500va UPS
Hi There I'm wanting to upgrade my APC Back-UPS 650va - BK650-AS with a 1500va UPS. Does anyone know of a 1500va UPS that would be recognised by ReadyNAS NVX Pioneer Edition? I Tried the Digi...
- Sep 23, 2017
I imagine similar APC models would also work.
Sep 23, 2017Guru - Experienced User
It should recognize a Cyberpower 1500va (at least my pro-6 does).
Trial_Master
Thanks I'll see where in Brisbane I can test one out first this time.
- StephenBSep 23, 2017Guru - Experienced User
- Trial_MasterSep 23, 2017Aspirant
Yes you'd think so, they are over double the price though.
The APC Back-UPS® Pro 1500 does appear to have the same connector though, so that could be promising.
