jaimeharris
Mar 27, 2012Aspirant
2 Dead Disks in two days
I have a ReadyNas Pro 4 running RAIDiator 4.2.19. I have 3x2TB in XRAID2. Disks are Seagate ST2000DL003-9VT166 1863 GB. I was backing up some things from my MacBook to the ReadyNAS wirelessly last ...
ReadySECURE
Mar 31, 2012Apprentice
jaimeharris, allow me to provide some insight on your situation. We recommend you do not enable root access as any damage to the software of the unit via SSH can cause the unit to not be supported. However, a large amount of the information that would be needed can be downloaded from the logs in Frontview. If you have not already, please contact Netgear support, as we will need to review the logs.
