netghiro
Jan 02, 2016Aspirant
312 vs 212: which CPU has more power and does better transcoding
As by subject.
Please now that the new 212 and 214 models are out, sporting a quad core (ARM Cortex A15 1.4GHz CPU) does anyone knows if they are more powerful than the 31x series (312, 314 sportin...
mdgm-ntgr
Jan 02, 2016NETGEAR Employee Retired
The 212 is better for transcoding. Transcoding will use all four cores.
The 312 has a higher clock speed, but is dual core. For tasks that only use one core I think the 312 may be faster. The 312 also supports a larger range of apps.
BrianL2
Hi netghiro,
You may also check each products datasheet for more information.
Kind regards,
BrianL
NETGEAR Community Team
- StephenBJan 02, 2016Guru - Experienced User
The data sheets aren't enough to compare the two CPUs. I also couldn't find any CPU benchmarks of the RN214 processor.
Though I suspect that mdgm is correct in saying
-a single core of the atom in the RN312 is probably faster than than a single core in the RN212 ARM
-but when all 4 cores of the RN212 are engaged, it is likely faster than the 2 cores of the RN312.
