Panzerbjørn
May 06, 2012Aspirant
3TB drive not recognised as such
I have just bought a brand new NV+ and installed two 3TB drive, but only 742GB are recognised from them. I saw another chap had a similar problem (http://www.readynas.com/forum/viewtopic.php?f=24&t...
May 06, 2012Guru - Experienced User
If you are running 4.1.x firmware you have a V1, if you are running 5.x.x. firmware then you have a V2.
If this is an NV+ V1, then it simply doesn't support 3 TB drives; there is no workaround.
