jlficken
Oct 16, 2019Aspirant
4 disk RAID 10 array....how do I tell which disks are striped?
I'm trying to figure out which disks are paired together as I'm moving data to another system and am going to canabalize the array for now. Everything is backed up so if something happens I'll be...
- Oct 17, 2019
jlficken wrote:Number Major Minor RaidDevice State 0 8 3 0 active sync set-A /dev/sda3 - 0 0 1 removed 2 8 35 2 active sync set-A /dev/sdc3 3 8 51 3 active sync set-B /dev/sdd3Would it seem logical that I can remove either disk 0 or disk 2 safely?
Yes, that is the case. It looks like you already removed disk sdb (bay 2) - which was mirrored by sdd (bay 4).
Oct 16, 2019Guru - Experienced User
I've never used RAID 10, so I'm not 100% sure. But perhaps download the log zip file, and look at mdstat.log.
- jlfickenOct 17, 2019Aspirant
Thanks!!!
I see this in that file:
Consistency Policy : unknown Name : 7c6e3906:MAIN-0 (local to host 7c6e3906) UUID : fd0716df:099c5648:d351a440:b82e32f5 Events : 13588 Number Major Minor RaidDevice State 0 8 3 0 active sync set-A /dev/sda3 - 0 0 1 removed 2 8 35 2 active sync set-A /dev/sdc3 3 8 51 3 active sync set-B /dev/sdd3Would it seem logical that I can remove either disk 0 or disk 2 safely?
Here's the full contents for that volume:
/dev/md/MAIN-0: Version : 1.2 Creation Time : Sat Mar 18 15:51:34 2017 Raid Level : raid10 Array Size : 15618353664 (14894.82 GiB 15993.19 GB) Used Dev Size : 7809176832 (7447.41 GiB 7996.60 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Thu Oct 17 12:35:48 2019 State : clean, degraded Active Devices : 3 Working Devices : 3 Failed Devices : 1 Spare Devices : 0 Layout : near=2 Chunk Size : 64K Consistency Policy : unknown Name : 7c6e3906:MAIN-0 (local to host 7c6e3906) UUID : fd0716df:099c5648:d351a440:b82e32f5 Events : 13588 Number Major Minor RaidDevice State 0 8 3 0 active sync set-A /dev/sda3 - 0 0 1 removed 2 8 35 2 active sync set-A /dev/sdc3 3 8 51 3 active sync set-B /dev/sdd3 1 8 19 - faulty - StephenBOct 17, 2019Guru - Experienced User
- jlfickenOct 18, 2019Aspirant
That is correct.
I knew I could remove 1 of the 4 drives without any issues (besides the array being "Degraded"), however, I wasn't sure how to know which drive to remove next so I came here.
They are all HGST HE8 UltraStar drives and I have a complete backup on another ReadyNAS so I'm not too concerned about running it degraded for a little bit while I am finishing the new NAS. The data from this volume will be moved over yet this morning via rysnc and then I can move on to the next volume.
Thanks again!
- Dec 25, 2018Retired_Member
