Robbie2017
Nov 29, 2017Aspirant
403 Forbidden Error
I have a ReadyNAS RN212. Software is 6.9.0 I am not techie, bought this to replace my old PC tower and have remote access for a student and a business. (I did assume this was plug and play, so regre...
RongqingL
Dec 04, 2017NETGEAR Expert
Hi,Robbie2017:
You can update your ReadyNAS to the latest firmware and sign out your readycloud account in your mobilephone then try again.
Thank you
- StephenBDec 05, 2017Guru - Experienced User
The current firmware is 6.9.1.
If you log into the NAS admin ui (https://nas-ip-address/admin) and go to the cloud tab, do you see green checkmarks for both ReadyCloud and the internet connection?
If you open your web browser to readycloud.netgear.com in a PC, can you access the files through that interface?
- Robbie2017Dec 05, 2017Aspirant
thanks StephenB, yes checked both and the checkmarks both green and i can access via browser. I have updated the firmware, signed out and back in as it was suggested and that worked. I need to check whether the rest of the family can now access, so will leave open temporarliy, thanks for the reply
i have updated the firmware, signed out and back in and that has worked thank you
