dannieboiz
Jul 29, 2014Tutor
4200 LACP with GS108T
I've successfully enabled LACP between the GS108T with my Server 2012 box and confirm that the connection is 2Gbe. I tried to do the same thing for the NAS but the hour clock just keeps on going and n...
mdgm-ntgr
Jul 29, 2014NETGEAR Employee Retired
WD Green drives are not suitable for use in the 4200. You should be using enterprise disks in that model.
You should check performance with multiple disks installed after the sync has completed.
With one disk installed you can't expect the performance you would get with an array with say 6 disks for example.
