dallis11
Apr 16, 2019Aspirant
4312X Expansion Options
The EDA4000 (24 bay expansion) has been flagged EOL -end of life and is very hard to find. Are there or will there be other expansion options for the 4312 NAS?
Thanks
Apr 16, 2019Guru - Experienced User
Netgear won't comment on their product plans, so you won't get any info on futures here. But there's nothing available today from Netgear.
I suspect that third party SAS/SATA expansion chassis will work, but of course it wouldn't be supported.
- HopchenApr 16, 2019Prodigy
Maybe you can do vertical expanssion as an interim alternative at the least. How big are the disks that you currently use?
- dallis11Apr 23, 2019Aspirant
Yes, that is the route I had decided to go but being that I'm purchasing a new 4360 I'm thinking that I would move data from the 4312 to the 4360 bay initially.
