dallis11
Apr 16, 2019Aspirant
4312X Expansion Options
The EDA4000 (24 bay expansion) has been flagged EOL -end of life and is very hard to find. Are there or will there be other expansion options for the 4312 NAS?
Thanks
Apr 16, 2019Guru - Experienced User
Netgear won't comment on their product plans, so you won't get any info on futures here. But there's nothing available today from Netgear.
I suspect that third party SAS/SATA expansion chassis will work, but of course it wouldn't be supported.
Hopchen
Apr 16, 2019Prodigy
Maybe you can do vertical expanssion as an interim alternative at the least. How big are the disks that you currently use?
- dallis11Apr 23, 2019Aspirant
Yes, that is the route I had decided to go but being that I'm purchasing a new 4360 I'm thinking that I would move data from the 4312 to the 4360 bay initially.
