dallis11
Apr 16, 2019Aspirant
4312X Expansion Options
The EDA4000 (24 bay expansion) has been flagged EOL -end of life and is very hard to find. Are there or will there be other expansion options for the 4312 NAS?
Thanks
dallis11
Apr 23, 2019Aspirant
Any drive recommendations on the 4360x NAS? Lots of Seagate on HD Compat list, HGST, West. Dig. Seagate seems problematic. Being that the 4360 is 60 bay drive vibration can be an issue. Thx.
- StephenBApr 24, 2019Guru - Experienced User
Definitely go with enterprise class drives. I generally use WD (and HGST is part of WD), but I think the Seagate Exos should also work well.
- dallis11Apr 24, 2019Aspirant
Thanks - Yes, for sure on nothing but Enterprise for the number of HDs and vibration.. Being that I have my 4312 loaded up with Exos I'll probably do that in the 4360 if you're saying Exos are good.
Just to clarify - I think they will work fine, but I don't have a rackmount NAS (and I use NAS-purposed drives on my own desktop NAS).
Netgear is often slow to qualify drives, but their testing is thorough. So any enterprise drive on their HCL should work.
