TeknoJnky
Nov 09, 2011Hero
a 3rd architecture? seriously?
I mean really, why? is it not confusing enough with 2+ sparc models and 9 x86 desktop models, that a 3rd architecture, which I am assuming will be requiring different addons and radiators releases...
PapaBear1
Nov 20, 2011Apprentice
gibxxi - if you are going to use Frontview for the NAS to NAS backup, the first backup is done with NFS and then the backup job is switched to rsync which keeps the two units synchronized according to the schedule you set. Unfortunately, the v2 versions of the NV+ and Duo DO NOT support rsync or NFS. So a third party backup solution must be used. (Unless some of the supports come up with Add-ons that will support NFS and rsync.
