davidr1
Jan 20, 2013Luminary
A complaint to Netgear
Notwithstanding the support in this forum which is superb, the community is saddened and the worse for departures and problems as raised in this thread http://www.readynas.com/forum/viewtopic.php?f=10...
mdgm-ntgr
Jan 20, 2013NETGEAR Employee Retired
/c is the data volume. Using X-RAID2 it would be the only data volume. The shares are stored on the data volume. It's called C because Windows users would be familiar with the hard disk in their PC by default being the C drive but NetGear could have decided to call the data volume pretty much anything else if they wanted to.
You can download your Config Backup (System > Config Backup) and have a look at some configuration files without needing to enable SSH.
There is a 4GB OS partition on the disks is mounted at / (this would be indicated in the logs - Status > Logs > Download all logs).
If you login via SSH and do
You can see that /media is a symlink to /c/media etc.
ls -la /
