ensign_fodder
Aug 19, 2011Tutor
A sad tale of ProSupport woe with ReadyNAS Pro Pioneer!
So I bought and equipped a ReadyNAS Pro Pioneer (6 Bay BYOD) NAS 7/2/2010 and added the ProSupport 24x7 Support and Maintenance upgrade. Overall I have been pleased with the unit (started with 4 x ...
ensign_fodder
Sep 07, 2011Tutor
Sun 8/21 @ 8:55 PM
Call Pro Support line and immediately answered call and was with a agent #5116
Was told how to reload OS from flash memory but instructions were wrong - told to use power button to select option not reset button
Called Pro Support back @ 9:01 PM after short time on hold agent #1375 answered
Heavy Indian accent - not technical then passed to #40168
Who:
11 hours later no response
Mon 8/22 @ 10:37 AM
Called Pro Support and near first ring answer connected to agent #78250
Who explained:
Who performed:
Meanwhile I received call from MJ (no agent number and another heavy Indian accent) about needing to open port 23/22 to allow static NAT traffic to pass
Agent #78250 called back and believes a fix is in place and I need to reboot unit to confirm but has no idea who MJ is or why I needed to open the port.
Unit reboots and seems to be operating normally. Continue to monitor S.M.A.R.T. errors on slot 5.
PHP Add-ons are still listed and seem to not be able to be removed, but that is for another day.
Who:
- Failed to understand network protocol enough to understand that if Telnet to port 80/443 fails then there is no way to connect to ReadyNAS FrontView
- Repeated asked unhelpful questions - I asked to be escalated - more useless questions - I asked what happened to domestic support and told she would collect information for level 3 support
- Asked about number of drives - capacity - model number - my external IP address - asked to open TELNET port through firewall - I told her Telnet (Port 23) is not working inside so why would outside work
- Asked me to open SSH (Port 22) - did so and confirmed working inside - confirmed working outside - told level 3 would investigate and "get back to her and she would get back to me"
Mon 8/22 @ 10:37 AM
Who explained:
- No need to open port due to prior tech misunderstanding how technology works
- Putting device into TECH MODE actually has it open outbound connection (firewall allows outbound instantiated connections) to NetGear NAS Shell Server
- I had been given wrong instruction and needed to use reset switch not power button to select
Who performed:
- Multiple attempts to fix flashing of OS by remove optional PHP add-on's, attempting to reload OS from new Download
- Having me re-enable Tech Mode and bump up to Engineering with a 24 to 48 hour response time unless identified issue sooner
