ensign_fodder
Aug 19, 2011Tutor
A sad tale of ProSupport woe with ReadyNAS Pro Pioneer!
So I bought and equipped a ReadyNAS Pro Pioneer (6 Bay BYOD) NAS 7/2/2010 and added the ProSupport 24x7 Support and Maintenance upgrade. Overall I have been pleased with the unit (started with 4 x ...
ensign_fodder
Mar 21, 2012Tutor
mdgm wrote: Would still suggest keeping the Pro Pioneer for backups. Data stored on a single device is not backed up.
True but data you cannot get to after it is backed up is worse then having no backup at all!
mdgm wrote: If you don't want to keep the Pro Pioneer you should be able to sell it either via the ReadyNAS Marketplace (http://www.readynas.com/forum/viewforum.php?f=33) or on a site such as eBay.
I fully expect I could pass this turd on to another for a decent price but would that really be fair to someone else?
If anything the possibility of using an ITX MB and the existing back-plane for a custom build is what I would want and if it dies in the process then I guess it was "the plan" from the storage gods!
Thanks!
