iau's avatar
iau
Ability to use 3TB disks on ReadyNas Duo
Hi,
I have a ReadyNas Duo with 2TB that are quickly filling up. I have been hoping that it would be possible to use 3TB disks when they get more common, but it doesn't seem so. Is the problem with compability connected to the hardware itself or is it a firmware thing? I have been very happy with my Duo, but are very reluctant to go for an other ReadyNas with larger capacity in case it will also be a dead end regarding firmware updates or whatever it takes to be able to upgrade disks after a while.
Keep checking back every other week or so, but the compability list doesn't grow. Will it ever?
Hoping for some good solutions here...
-iau
  • A user in the ReadyNAS community has tested some 4TB drives in a few x86 ReadyNAS units and found them to be working. Whilst this is by no means conclusive it is a good sign that 4TB drives may already be compatible with x86 ReadyNAS units.
    Travesti.
  • Seems it may work after all:
    http://www.atlastsolutions.com/netgear-readynas-duo-v2-6tb-2x-3tb-raid-nas-network-server-readynasv2-6tb/
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Two very different products with very different hardware, OS etc.
    Duo v2 (runs RAIDiator 5.3.5 and available for purchase from Nov 13th 2011) supports 3TB drives
    Duo v1 (runs RAIDiator 4.1.x or earlier) supports disks up to 2TB in capacity.
  • So... has anybody been able to run anything larger than 2TB drives in their ReadyNAS Duo V1?
  • StephenB's avatar
    It doesn't do it. 2 TB is the limit.
  • Thanks, I was hoping someone had hacked the firmware or controller to allow it by now. I guess I need to look at V2...
  • StephenB's avatar
    Or the x86 models (pro-2 or ultra-2)
  • v1 readynas duo not supporting 3TB kinda sucks...but i'm hoping the work around is to to simply use the usb ports on it.
    FYI there is a good background article on why things changed when hdds jump from 2TB to 3TB...
    http://www.pcworld.com/article/235088/e ... rives.html
    ...I've read also that also impacts some media players, smart tvs etc that simply dont know how to handle the large drives.
    While it the v1 may not support 3TB internal SATA, it may be worth searching for success stories of external 3TB being connected via USB.
    I just connected my seagate external 3TB to my v1 duo (2xbay), looking under Volumes -> USB Storage Devices it came up with this:
    USB_HDD_9 2794 GB No Filesystem 480
    I could potentially format it as EXT3, but i'd need to investigate to see if would work before trying it out (i have all my data backed up on it, and not keen to wipe!).... keen to hear if anyone else has tried this?
    Dek
ProSupport for Business
