SiDuB
Apr 05, 2019Aspirant
Access Drobo Shares
Equipment:
NAS1 = Drobo5N - 10TB
NAS2 = RN214 - 16TB
Router = Nighthawk X10 R9000
Modem = CM700
PC = Intel i5
So right now i run PLEX on the PC and all is going good. I have my Movies an...
- Apr 06, 2019
Sandshark wrote:
I think you are better off using Plex itself to find the other NAS share,
That can't be done, since Plex doesn't allow you to add a network share to its library. SiDuB can't find the network browse feature in Plex because there isn't one.
So he does need to mount the share (as he is already doing on the Windows PMS by mapping them to drive letters). In Linux, they need to be mounted on "mount points" - which basically are "placeholder" folders.
Sandshark wrote:
If you really do want to mount the share on your ReadyNAS, here are some ways: 8-ways-to-mount-smbfs-samba-file-system-in-linux//
This of course requires ssh. Something along these lines will work, but as Sandshark says the methods 1-5 in the link aren't sticky (you'd need to redo them whenever you reboot either the NAS or the Drobo).
You can create an empty share on the NAS called "Drobo", and create subfolders for each media share on the Drobo that you want to include in the ReadyNAS PMS. These are the placeholders (e.g, the mount points). You mount the Drobo shares on those subfolders, and then add those subfolders to the ReadyNAS PMS library.
Once you get this all working, you could attempt to modify /etc/fstab (perhaps using method 6), so it would automatically do these mounts whenever the NAS is booted up. I suggest making a copy of the fstab file, and then editing the copy. After that looks right, you can rename the your file to fstab.
All this is a fair amount of work to do for a hypothetical situation. Not sure it's really worth the effort.
schumaku wrote:
Forget DFS.
Well, obviously it isn't working, so he has to. But if it had worked, it would have allowed him to achieve his goal w/o using SSH.
SiDuB
Apr 06, 2019Aspirant
Thank You Everyone for the help, i was able to figure it out, i added the NFS app to my drobo and then went to configure it and it showed me the addresses i sould be using.
for TNC-MOVIES
mount 192.168.1.13:/mnt/DroboFS/Shares/TNC-MOVIES /data/TNC-MOVIES
for TNC-MUSIC
mount 192.168.1.13:/mnt/DroboFS/Shares/TNC-MUSIC /data/TNC-MUSIC
Now i was ready the #6 on that site and combined the two and hopefully it will work on a reboot.
for TNC-MOVIES
#vi /etc/fstab//192.168.1.13:/mnt/DroboFS/Shares/TNC-MOVIES /data/TNC-MOVIES nfs rw 0 0
and for TNC-MUSIC
#vi /etc/fstab//192.168.1.13:/mnt/DroboFS/Shares/TNC-MUSIC /data/TNC-MUSIC nfs rw 0 0
and then i went on to the PMS on my RN214 and was able to see the mounts and it populated my Plex Movie folder.
Thanks again everyone
