powellandy1
Aug 21, 2020Virtuoso
Add SSD to RN528X
Hi Following on from https://community.netgear.com/t5/New-ReadyNAS-Users-General/Add-SSD-drive-s-to-RN528X/td-p/1776859 I've just had a go at adding an M2 SSD to my new 528X. It seems have wo...
powellandy1
Feb 13, 2021Virtuoso
Hi
root@MediaMaster:~# lspci|grep SATA 00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05) 05:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) 06:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) 09:00.0 SATA controller: Marvell Technology Group Ltd. Device 9170 (rev 13)
and
root@MediaMaster:~# lsscsi [0:0:0:0] disk ATA WDC WD140EMFZ-11 0A81 /dev/sda [1:0:0:0] disk ATA WDC WD140EMFZ-11 0A81 /dev/sdb [2:0:0:0] disk ATA WDC WD140EMFZ-11 0A81 /dev/sdc [3:0:0:0] disk ATA WDC WD140EMFZ-11 0A81 /dev/sdd [4:0:0:0] disk ATA WDC WD140EDFZ-11 0A81 /dev/sde [5:0:0:0] disk ATA WDC WD140EDFZ-11 0A81 /dev/sdf [6:0:0:0] disk ATA WDC WD140EMFZ-11 0A81 /dev/sdg [10:0:0:0] disk ATA TS120GMTS420S 9A0 /dev/sdh
Cheers
A
spiperov
Feb 15, 2021Guide
Hmmm... This is interesting - from your lsscsi output one might conclude that you have 7 disks connected to the 6-channel SATA controller that's built into the D-1508 CPU. Which - if true - implies the presense of a SATA switch (on the HDD backplane?).
Maybe if you also post the output of 'ls -al /sys/block/sd*' ?
Here's my output for reference:
root@RN526X:/data/tmp# ls -al /sys/block/sd* lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sdb -> ../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sdc -> ../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sdd -> ../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Jan 13 02:07 /sys/block/sde -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 Jan 13 02:07 /sys/block/sdf -> ../devices/pci0000:00/0000:00:1c.0/0000:05:00.0/ata11/host10/target10:0:0/10:0:0:0/block/sdf lrwxrwxrwx 1 root root 0 Jan 31 14:18 /sys/block/sdg -> ../devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.1/3-2.1:1.0/host13/target13:0:0/13:0:0:0/block/sdg
- powellandy1Feb 15, 2021Virtuoso
Hi
root@MediaMaster:~# ls -al /sys/block/sd* lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sdb -> ../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sdc -> ../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sdd -> ../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sde -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sdf -> ../devices/pci0000:00/0000:00:1f.2/ata6/host5/target5:0:0/5:0:0:0/block/sdf lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sdg -> ../devices/pci0000:00/0000:00:03.0/0000:05:00.0/ata7/host6/target6:0:0/6:0:0:0/block/sdg lrwxrwxrwx 1 root root 0 Feb 15 13:13 /sys/block/sdh -> ../devices/pci0000:00/0000:00:1c.0/0000:09:00.0/ata11/host10/target10:0:0/10:0:0:0/block/sdh
Andy
- spiperovFeb 15, 2021Guide
Interesting!
So your 7th HDD is attached to one of the ASMedia SATA controllers (the 05:00.0 in the 'lspci' output), and the M.2 disk is attached to the Marvel chip - same as on the RN526X.
In principle they could have used a single ASM1062 chip, because it provides 2 SATA channels. But maybe the NETGEAR engineers were not happy with the performace of that chip when used with 2 disks, so they added two chips on the motherboard.Thanks for this useful info!
- Stefan
