JuhaH
Feb 25, 2019Aspirant
Adding another pair of drives?
Hi all,
This has been propably asked thousands of times, but I could not answer and I'm asking again. I have ReadyNAS 526X with pair of 6 TB disks. I installed another pair hoping to get 12 TB ...
- Feb 25, 2019
JuhaH wrote:
So I can leave the system as it is and if there will be singe disk failure, I should be safe. Of course I create backups into an external drive frequently.
Yes.
JuhaH wrote:
I have one disk showing occasional error messages. I might consider replacing it.
What errors are you seeing?
JuhaH wrote:
I also wonder why I get "Unrecognized server error", when updating firmware manually. I'm currently running on 6.9.3.
I haven't seen that in quite a while. What browser are you using?
Feb 25, 2019Guru - Experienced User
JuhaH wrote:
What did I do wrong and how can I fix this? I want to see both pairs mirrored.
As Marc_V says, XRAID is designed to switch to RAID-5. You still have single redundancy (protection against a single disk failure).
Did you want two RAID-1 volumes? Or RAID-10??? Maybe explain the rationale, as you might be better off with your current RAID configuration.
- JuhaHFeb 25, 2019Aspirant
Thanks for Your answers,
So I can leave the system as it is and if there will be singe disk failure, I should be safe. Of course I create backups into an external drive frequently. I have on disk showing occasional error messages. I might consider replacing it.
- StephenBFeb 25, 2019Guru - Experienced User
Yes.
- JuhaHFeb 26, 2019Aspirant
I think the errors were Sata errors.
I did use Microsoft Edge.
I cannot confirm errors at the moment. It seems the workstation I've used as ReadyNAS admin has lost the password to RN526 last night while I was away. None of my RN Passwords I've written down on paper is not working there. Do I need to reset the whole thing to recover my password?
