JuhaH
Feb 25, 2019Aspirant
Adding another pair of drives?
Hi all,
This has been propably asked thousands of times, but I could not answer and I'm asking again. I have ReadyNAS 526X with pair of 6 TB disks. I installed another pair hoping to get 12 TB ...
- Feb 25, 2019
JuhaH wrote:
So I can leave the system as it is and if there will be singe disk failure, I should be safe. Of course I create backups into an external drive frequently.
Yes.
JuhaH wrote:
I have one disk showing occasional error messages. I might consider replacing it.
What errors are you seeing?
JuhaH wrote:
I also wonder why I get "Unrecognized server error", when updating firmware manually. I'm currently running on 6.9.3.
I haven't seen that in quite a while. What browser are you using?
Feb 25, 2019Guru - Experienced User
JuhaH wrote:
What did I do wrong and how can I fix this? I want to see both pairs mirrored.
As Marc_V says, XRAID is designed to switch to RAID-5. You still have single redundancy (protection against a single disk failure).
Did you want two RAID-1 volumes? Or RAID-10??? Maybe explain the rationale, as you might be better off with your current RAID configuration.
JuhaH
Thanks for Your answers,
So I can leave the system as it is and if there will be singe disk failure, I should be safe. Of course I create backups into an external drive frequently. I have on disk showing occasional error messages. I might consider replacing it.
- StephenBFeb 25, 2019Guru - Experienced User
Yes.
- JuhaHFeb 26, 2019Aspirant
I think the errors were Sata errors.
I did use Microsoft Edge.
I cannot confirm errors at the moment. It seems the workstation I've used as ReadyNAS admin has lost the password to RN526 last night while I was away. None of my RN Passwords I've written down on paper is not working there. Do I need to reset the whole thing to recover my password?
- StephenBFeb 26, 2019Guru - Experienced User
Chrome tends to work better with the NAS. Though if you don't want to click through the security warnings, FireFox is the best option (since you can save the security exception).
JuhaH wrote:
I cannot confirm errors at the moment. It seems the workstation I've used as ReadyNAS admin has lost the password to RN526 last night while I was away. . Do I need to reset the whole thing to recover my password?
Do an OS reinstall, using the procedure on pages 137-138 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf.
That will
- reset your admin password to password
- reset your NIC configuration to DHCP (and turn off bonding)
- turn off volume quota
Other settings (and of course your files) shouldn't be affected.
FWIW, since anyone with physical access to the NAS can also do the OS reinstall, there's not much security risk in putting the password on a label on the chassis (for instance inside the door).
After you regain access, download the log zip file. The SMART stats for the disks are in several places, including disk_info.log.
