darrens
Oct 08, 2011Aspirant
Additions to FAQ
I recently had a nightmarish experience updating the hard disks in my ReadyNAS (partly described here http://www.readynas.com/forum/viewtopic.php?f=64&t=57565). A lot of the problems I had was finding...
Oct 09, 2011Guru - Experienced User
I agree the FAQs could use some updating.
I've seen "corrupt boot partition" when inserting a used (but not erased) disk into the NAS. So that is another thing that could be added to that section - it is not necessarily memory.
Also, if you have add-ons, either you need to customize the config backup, or you need to re-install them before doing the config restore. If you do neither, you will need to go back to factory defaults (or mess with shell commands I guess) to put things right.
At least some of the material from sphardy's site would also be nice to have in the FAQs (with his permission of course).
