SimonCurry
May 13, 2019Aspirant
Admin ID/Password not working after recent firmware upgrade
I have been using my ReadyNAS device for many years with no problems.
A recent firmware upgrade has seemed to blow away my RAIDar admin id/password that has always worked fine until this upgrade.
- May 13, 2019
Hi SimonCurry
Have you tried using a different browser or clearing cache before proceeding logging in on the Admin page or with the Password Recovery? If you have done this but still not getting access to your Admin page then an OS Reinstall can be done to reset the NAS Admin credentials to default.
Default credentials for NV+ V2 should be admin/password
To perform OS-Reinstall you can check this link.
Hope this helps!
Regards
May 13, 2019Guru - Experienced User
What firmware were you installing? What was the NAS running before?
In addition to Marc_V's suggestions, you could check the status using RAIDar: https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
SimonCurry
May 14, 2019Aspirant
Marc,
Not too sure as I cannot access admin panel any more. As I keep upgrades up to date i presume it is the latest version of firmware as prompted by admin panel.
S
- StephenBMay 14, 2019Guru - Experienced User
SimonCurry wrote:Not too sure as I cannot access admin panel any more.
Did you try to confirm with RAIDar?
