Aug 10, 2021Follower
Admin password reset RBR20
I need to reset the admin password and understand there is a way to manually reset it. Please let me know who to send a direct message to. Thank you.
Aug 10, 2021Guru - Experienced User
You are in the wrong forum area, this is for ReadyNAS storage products, not for Orbi.
But to answer your question, there are two ways to reset your admin password. If you enabled password reset, you can use the procedure on page 93 in the user manual. Whether you did or not, you can use the reset pinhole to reset the router to factory default settings as described on page 142.
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
