ToddeSwe
Sep 01, 2021Guide
Admin settings keeps loading over and over again with the latest firmware.
Hi Having some strange things happening here. I reinstalled my OS on my ReadyNAS 102 yesterday and today when i was trying to go to settings i couldn't use my default password. Installed AVAST to...
- Sep 06, 2021
ToddeSwe wrote:
The use of the system volume root is 95%. This condition does not usually occur under normal conditions. Contact technical support.
This is the OS partition ("system volume root"). It's not about how much data you have stored on the NAS. The full OS partition might be linked to the difficulty in getting the hotfix installed.
There are three ways to fix this:
- Engage paid Netgear support to do it for you remotely. This will require purchase of a support contract.
- Backup all your data, do a factory default, and set the NAS up again.
- Fix it yourself with ssh.
Since you really don't have much data on the NAS, option 2 is what I'd suggest. If you have no experience with the linux command line, I don't recommend option 3.
Sep 12, 2021Guru - Experienced User
ToddeSwe wrote:
I don't know if i should start a new thread or just continue with my problems here?
I've now factory restored the NAS but i can't see any apps at all, why is that?
Tried to download and install manually but got a mail that said it did not work.
Cannot install application transmission6.
It can take a little while for the available apps page to populate.
Manually upload should work though - did you try transmission NT (which I think is newer than transmission)? Did you install arm version?
ToddeSwe
Sep 12, 2021Guide
StephenB wrote:
ToddeSwe wrote:I don't know if i should start a new thread or just continue with my problems here?
The system (NAS) has been up for 6.5 hours now ... seems a long time for it to kick in ... :)
I was using the all version since there is just one version, downloaded and tried the nt version as well but that one failed as well.
I know i have internetcontact because of it checks for new version and adjusts the time.
Do i have to turn something on in this settingsscreen, see attached picture.
