ToddeSwe
Sep 01, 2021Guide
Admin settings keeps loading over and over again with the latest firmware.
Hi Having some strange things happening here. I reinstalled my OS on my ReadyNAS 102 yesterday and today when i was trying to go to settings i couldn't use my default password. Installed AVAST to...
- Sep 06, 2021
ToddeSwe wrote:
The use of the system volume root is 95%. This condition does not usually occur under normal conditions. Contact technical support.
This is the OS partition ("system volume root"). It's not about how much data you have stored on the NAS. The full OS partition might be linked to the difficulty in getting the hotfix installed.
There are three ways to fix this:
- Engage paid Netgear support to do it for you remotely. This will require purchase of a support contract.
- Backup all your data, do a factory default, and set the NAS up again.
- Fix it yourself with ssh.
Since you really don't have much data on the NAS, option 2 is what I'd suggest. If you have no experience with the linux command line, I don't recommend option 3.
Sep 13, 2021Guru - Experienced User
Ok.
Are you seeing apps in the available apps page yet? Or is that page still empty?
ToddeSwe
Sep 13, 2021Guide
StephenB wrote:Ok.
Finaly i can see the apps. :) I have installed Transmission as well but now i'm having problem configuring it.
Gives me toddenas:8181 error when trying to connect. Even though i use the default name and password i can't login to it.
But that isn't your problem so i have to ask someone else about that i guess.
Wonder why i can't manually install it though...
