fondy's avatar
fondy
Tutor
Feb 15, 2021
Apache conf files and security
Hi Use OS 6.10.4 on a Readynas Pro2. Using the NAS for websites, installed Mysql, PHPAdmin, and PHP 7.4. The OS installed the Apache server
I see in my Apache Error log that there are many visitors from China, USA, etc that are trying to install harmfull software.
I use the standard apache2.conf that OS 6.10.4 installed
I am using this in my private conf file for my sites, here is an example:
DocumentRoot /xx/xx/xx/xx
ServerName xxxx.yyyy.com
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
   <Directory "/xx/xx/xx/xx/">
      IndexOptions +FancyIndexing NameWidth=*
        Options Includes FollowSymLinks Indexes ExecCGI
        AllowOverride
        All Require all granted
   </Directory>
</VirtualHost>
Is there something I can put in the apache2.conf file for security?
In my Virtual host file, is there something I should correct, delete or change?
Regards Paal
    • Sandshark's avatar
      Sandshark
      Sensei
      It might help others with a similar problem that are searching the forum if you describe your fix.
ProSupport for Business
