MrTAZ
Aug 17, 2016Star
Apache security
Hi,
I'm worried to discover that apache is setup with THE admin user and group.
Some people did use it to host his website.
Why it's worry? If an apache/php hack is used, all datas are compromised!
I'd tried to install mpm-itk but apache version of readynas isn't compatible.
Can you plan a fix to run with another user?
Regards.
- mdgm-ntgrNETGEAR Employee Retired
Which model is this and which firmware are you running?
- RN104 6.5.0
(Downgraded in techsupport mode After 6.5.1 because mvxor+88, beta 6.5.2 don't boot)
