fdm_
Apr 20, 2016Aspirant
APC BE550G support
Hi, I had a ReadyNAS 204 (4-bay ARM processor) and an APC BE550G. Do we know if there are plans to release an app for this UPS?
fdm_
Apr 29, 2016Aspirant
That's correct. When I go to Power - UPS I see "No UPS is configured for this system." If I click add I have the options SNMP and remote.
JennC
May 03, 2016NETGEAR Employee Retired
Hello fdm,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
