fdm_
Apr 20, 2016Aspirant
APC BE550G support
Hi, I had a ReadyNAS 204 (4-bay ARM processor) and an APC BE550G. Do we know if there are plans to release an app for this UPS?
Alan_Shore
Aug 01, 2016Aspirant
As far as I know, there isn't any app for the apc be550g ups model!
Aug 01, 2016Guru - Experienced User
There are no apps for any UPS.
The NAS has built-in UPS support using NUT (Network UPS Tools). The NAS should recognize the UPS when you connect a USB cable between the UPS and the NAS.
- BrianL2Aug 01, 2016NETGEAR Employee Retired
Hi fdm_ & Alan_Shore,
StephenB is right. Check these following articles on how to add and install or UPS on your ReadyNAS system.
How do I use uninterruptible power supplies (UPS) with my ReadyNAS OS 6 storage system?
How do I add a UPS to my ReadyNAS OS 6 storage system?
Kind regards,
BrianL
NETGEAR Community Team
