Alien
Jan 04, 2008Aspirant
APC UPS Client Add-on or Widget
** Moved from Developement Forum ** Hey guys, would it be possible to load a linux base client that would work with the APC Net Manager? I have a TCP/IP based connection to my APC UPS and would ...
dlipowsky
I'd check the NUT HCL to see if your UPS is listed and go from there.
http://www.networkupstools.org/compat/stable.html
If you're referring to the APC SNMP management card, there appears to be drivers available for it. If you're comfortable with this you should be able to make this work far quicker than waiting for them to deliver an APC add on.
