Alien
Jan 04, 2008Aspirant
APC UPS Client Add-on or Widget
** Moved from Developement Forum ** Hey guys, would it be possible to load a linux base client that would work with the APC Net Manager? I have a TCP/IP based connection to my APC UPS and would ...
nycvelo
Apr 07, 2008Aspirant
> NUT supports the APC SNMP card...
Yes, but that's a non-starter at least for me. We already have a bunch of APC gear, and apcupsd running on everything to control it.
It's not a good solution to force me to dedicate a separate APC UPS and then have to set up NUT just to control 1100s, especially since everything else in our network uses apcupsd...
thanks
thanks
