Alien
Jan 04, 2008Aspirant
APC UPS Client Add-on or Widget
** Moved from Developement Forum ** Hey guys, would it be possible to load a linux base client that would work with the APC Net Manager? I have a TCP/IP based connection to my APC UPS and would ...
schalliol
Jan 25, 2009Aspirant
ianmacd wrote:
schalliol wrote: Did you not see my posting earlier in this thread?
Yep, I did see it. Did you read the text you quoted? I'm looking to "make NUT on the ReadyNAS...talk with the card directly." It seems the way you did it requires a remote machine talk with the card and then the NAS talks with that machine. However, I presume if you can put a service on a Linux box that reads from the card directly, we can do the same on the ReadyNAS...however, I'm not sure how to install and configure it. Perhaps might we install the server and then configure the client on the NAS to look internally? Ideas?
