Alien
Jan 04, 2008Aspirant
APC UPS Client Add-on or Widget
** Moved from Developement Forum ** Hey guys, would it be possible to load a linux base client that would work with the APC Net Manager? I have a TCP/IP based connection to my APC UPS and would ...
nycvelo
Feb 14, 2009Aspirant
OK, I've just spent a few days playing with NUT and found it wanting. It won't directly work with some virtual machines to shut them down earlier then the host machine. I asked about this on the NUT mailing list and the response was "that's VMWare's problem." FAIL.
apcupsd works fine with every single system we have except the ReadyNAS.
I won't buy anymore ReadyNASs until either (a) Netgear adds support for direct control of the UPS from the ReadyNAS via NUT or (b) Netgear adds support for apcupsd. (b) would be my strong preference.
