Idward
Aug 05, 2022Aspirant
App images are not loading
I am seeing a strange issue where all apps, both installed and available do not load any images, and I do not recall it ever properly loading images. Is there a simple solution for this? Model: R...
Aug 05, 2022Guru - Experienced User
Are the installed apps running?
Is "internet available" checked on the cloud page?
- IdwardAug 06, 2022Aspirant
Yes, the installed apps are running.
The cloud page says there is internet and they have the images (if that matters)
I checked on the backend and found that the logo.png files do exist for the installed apps. - IdwardAug 09, 2022Aspirant
The cloud page says there is internet, and they have the images (if that matters)
