miogpsrocks
Nov 25, 2015Tutor
Are 4TB Hard drives ok for the XRAID2 Firmware ?
Hi. I have a 6 drive bay Readynas with the X-raid 2 firmware and I'm wondering if I can fill it up with 4TB hard drives? Thanks. P.S. What the heck happen to this forum. Where is the blue...
- Nov 26, 2015
Yes. Doing a factory reset you will be able to fully utilise the space on the disks.
miogpsrocks
Nov 25, 2015Tutor
I believe the exact model number that I have:
Netgear ReadyNAS Pro RNDP600E Pioneer edition
P.S. Why does this website look so werid?
mdgm-ntgr
Nov 25, 2015NETGEAR Employee Retired
On the compatibility list under Legacy > ReadyNAS Pro Pioneer Edition there is a 4TB disk.
Do be aware of the expansion limitations of RAIDiator-x86 4.2.x:
1. You cannot expand a volume by more than 8TB over the life of the volume
2. You cannot expand the volume past 16TB. To get a higher capacity volume you would need to do a factory default (wipes all data, settings, everything) with the disks in place.
- miogpsrocksNov 25, 2015Tutor
I am usually too scared to trust the expansion and usually build my readynas systems to the max instead of slowly expanding it even though I know it can technically be done.
I am confusued by what you mean by " You cannot expand the volume past 16TB. To get a higher capacity volume you would need to do a factory default (wipes all data, settings, everything) with the disks in place."
Are you saying that it will be maxed out at 16TB or only if you are expanding it?
In other words, is it possible to get 24TB( 4TB drives X 6 bays) if you do the factory default and a fresh install?
Thanks.
- mdgm-ntgrNov 25, 2015NETGEAR Employee Retired
The latter.
6x4TB drives in RAID-5 would give a volume capacity above 16TB. You would need to do a factory default to get a volume of this capacity.
Using RAID-6 the volume capacity would be below 16TB.- miogpsrocksNov 25, 2015Tutor
When you say 16GB can be achieved by the factory default option, are you assuming that I am using a 4-bay system or taking into account that I have a 6-bay system?
Since I am using a 6 bay system, I would normally assume that 6 X 4 = 24, in raid 5 you would have 1 drive for parity and end up with 20 GB of usable space normally.
Are you saying there is a limit in the system to 16GB regardless if how many hard drives bays or what their size, the limit will never be more than 16GB?
I just want to make sure I understand you correctly and you are factoring in that I'm using a 6 drive system and not a 4 drive system?
Thanks.
