aerius
Jul 03, 2013Aspirant
As firewall/router
Hello everyone! Got one quick question about the ReadyNAS 104 series. It got dual ethernet ports which to me looks like I can use it as a router and firewall? Is this possible? I see that Synolog...
Jul 06, 2013Guru - Experienced User
I don't think you can use it as a layer-2 switch. With work you could route, but I don't recommend it. You're better off getting an ethernet switch if you need one.
arnomc wrote: MMmhh about the dual ethernet, I would like to plug an networked inkjet printer on the second ethernet port and use the NAS as a switch (with same networks settings). So no security problems in my case. I am planning to 'upgrade' my Ultra 2 to OS 6.
