Post
May 21, 2013Aspirant
Backup 316/516 to Ready Nas Pro 6
Hi, I am interested in upgrading to one of the newly released products but wondering if it will work to backup via cloud/replicate to an older pro model? Or is RSYNC still a better option for o...
Post
May 22, 2013Aspirant
chirpa wrote: You can use Replicate across the platforms, as long as you buy licences for each machine.
Rsync will work, ideally Rsync+SSH for compression/security.
I believe Replicate should be much easier to setup, however I have read mixed reviews on it. Would you have any experience as to recommend it? Or will I be better off in the long run if I stick to RSync+SSH? If so, would you know of any threads that deal with the setting up of Rsync + SSH over the internet? I am running two identical Pro 6 with Raidiator. Thank you!
