Dede_Ayache
Apr 03, 2020Aspirant
BackUp into Google Drive
ReadyNas Ultra 6Plus fw 6.10.3 Hello everyone i am sure this question was discussed here, but i could not find the answer to this. i want to back up my Shares into Google Drive look...
- Apr 11, 2020
Thank you!
Luckily i fount the solution!the right way to enter the values is like in this picture
JohnCM_S
Apr 03, 2020NETGEAR Employee Retired
Hi Dede_Ayache,
It seems to me all the settings on your Google Drive sync appears to be correct.
Have you checked the DNS settings of the NAS? You may try assigning a static DNS on it and see if that will help. You can use your router's IP address and Google's DNS addresses (8.8.8.8 or 8.8.4.4) for the DNS addresses.
You can also use this article for the steps in configuring Google Drive on the NAS.
- Dede_AyacheApr 11, 2020Aspirant
Thank you!
