C-R-S
Jan 13, 2019Aspirant
Backup keeps failing
Hello
looking for some support i have a readynas 204 and i am tying to set up a backup from the readynas 204 to a readynas duo each time i run the back up it fails.
all the data is back u...
Jan 14, 2019Guru - Experienced User
It would be helpful if you could post the backup job settings.
Also, did you enable rsync on the duo's destination share?
