Gearmeister
Oct 20, 2019Aspirant
Backup ReadyNas 214 to External Drive
I'd like to back up my ReadyNAS 214 and its current contents. The shares have both Windows and Mac files on them. I understand that things can go south quickly when formats mistmatch. So, if i b...
Marc_V
Oct 21, 2019NETGEAR Employee Retired
Welcome to the Community!
Since you both have Windows and Mac OS I would go with the FS that you will be able to access on different systems. I think the best option would be to go with NTFS.
While it is mainly for Windows, I think Mac OS provides support already. Also, if you can setup a different external for MacOS then that would be best.
HTH
Regards
Oct 21, 2019Guru - Experienced User
The Mac does have built-in read support for NTFS, so I agree that is the best format for the backups.
There are some third party packages that can add write support (Paragon being one).
- SandsharkOct 21, 2019Sensei
If your desire is to restore the NAS from the backup, then EXT4 would be best. But if you may need to get a file directly from the drive to the Windows or Mac system, then NTFS.
