Entomon
Dec 05, 2017Follower
Backup to DropBox
non riesco ad attivare Dropbox da ReadyNAS
RongqingL
Dec 05, 2017NETGEAR Expert
Hi, Entomon:
To set up Dropbox backup on your system:
- Log in to your ReadyNAS.
- Select Cloud.
- Set the Dropbox On-Off slider so that the slider shows the On position.
A new browser window opens and takes you to https://www.dropbox.com.
- Log in to your Dropbox account.
A message displays asking if you want to allow the ReadyNAS to access your Dropbox account.
- Click the Allow button.
The Dropbox - Session window opens.
- Use the Local Path Browse button to navigate to and select a location on the ReadyNAS to sync to Dropbox.
- Use the Cloud Storage Path Browse button to navigate to and select a location in Dropbox.
- Select a sync direction, Bidirection, Download cloud storage changes only, or Upload local storage changes only.
- Click the Create button.
The Dropbox - Session window closes. The Dropbox On-Off slider is now in On position. The combination of local path, Dropbox location path, and sync direction is called a session.
Thanks
