jhicks
Mar 26, 2012Aspirant
Bad sectors reported but not found
I have a ReadyNAS NV which has been faithful and terrific for years. I have even upgraded the original disks to Seagate 1TB drives and they have run more or less without fail. Recently ReadyNAS has be...
Mar 26, 2012Guru - Experienced User
What do the SMART statistics say? These are reported by the drive itself. So if the SMART statistics say there are reallocated sectors, then there are.
Because the bad sectors have been reallocated, the failures might not have created data loss yet. Also, Seagate tools might still pass, since they use fairly large thresholds for reallocated sectors.
However, if you are seeing these rates go, you should replace the drive without delay.
