jhicks
Mar 26, 2012Aspirant
Bad sectors reported but not found
I have a ReadyNAS NV which has been faithful and terrific for years. I have even upgraded the original disks to Seagate 1TB drives and they have run more or less without fail. Recently ReadyNAS has be...
Mar 26, 2012Guru - Experienced User
If I had 63 reallocated sectors, I would replace the disk.
If it is still under warranty Seagate will take the RMA (though you would need to enter a self-service code - I suggest 659DC7AE). Also if you are in the US, you should probably pay them to ship you the replacement first - this is quite inexpensive (not much more than your shipping costs) and it gets you a drive much quicker.
