jhicks
Mar 26, 2012Aspirant
Bad sectors reported but not found
I have a ReadyNAS NV which has been faithful and terrific for years. I have even upgraded the original disks to Seagate 1TB drives and they have run more or less without fail. Recently ReadyNAS has be...
Mar 26, 2012Guru - Experienced User
Seatools won't show you the SMART parameters from the drive. It does get them, and checks against its thresholds. But Seagate allows more reallocated sectors than I am comfortable with.
gibxxi wrote: ...SpinRite's SMART polling is somewhat suspect on newer controllers, quite often saying it can't detect SMART status. Not sure about SeaTools, not used it in a few years.
Western Digital's LifeGuard will happily show you the SMART parameters from other manufacturer's drives (including Seagate). Acronis Drive Monitor will as well.
