BobFord
Apr 05, 2018Aspirant
Best Expansion Unit for Netgear NAS
I have an RN628X unit and am looking to put an expansion unit to take at least 5 HDD's (3.5" SATA). What is the panels view of best options? TVMIA Bob
- Apr 05, 2018
Thanks all for the comments - much appreciated
I think short term, I'll go for the multi-bit and then look to expand the NAS suite in due course
BobFord
Thanks Marc
All search results in the UK are showing as this device is discontinued.
Are there other units that users herein would recommend?
mdgm-ntgr
Apr 05, 2018NETGEAR Employee Retired
Adding a second NAS unit to your network would add better performance than an expansion unit and expansion units should have a separate data volume anyway.
You could add a RN426, RN428, RN526X, RN528X, RN626X or RN628X to your network.
- StephenBApr 05, 2018Guru - Experienced User
I agree. It's also more robust.
Also, if you want to transfer information between the two NAS you might consider getting an RN500 or RN600 series (with 10GBASE-T) and add a multigig switch. This should outperform NIC bonding. Netgear's offerings for that are here: http://www.netgear.com/landings/multi-gig/
- BobFordApr 05, 2018Aspirant
